Pulling the tranny, how much clearance do I need below the truck?
V8Notch
I'm pulling my 5spd tranny from my 2000 4x4 to do the clutch.
How much clearance do I need below the truck? I am only going to use jackstands, no lift.
Thanks.
kunar
131
Toledo, Ohio
5.8l
i've done mine with all 4 flat on the ground. you don't need much, jack stands will be fine.
locovaca
4
DeWitt, IA
I can vouch for the jackstands, It'd be a little tight just on the ground by my memory but with the jackstands I had no problems.
Uly The Hermit
I've only done it once ('99 with auto trans) and I very carefully determined how high the jack stands needed to be so that I would be able to get the trans out. I ended up having to jack up the front of the truck to get it out.
Earl43P
38
Farmington, Pa
Ford F250 4WD
I've done 2wd with all 4 wheels on cinderblocks, holes up, with wood in the holes as chocks.
Gives you plenty of room for the DRIVESHAFT BOLTS (you'll need to swing a breaker bar if not using an air impact).
