Pulling engine
budro
Is it possible to pull the 4.0 and A4LD out of a 92 ranger together without taking out the radiator core support? This truck has no lift whatsoever on it.
BlackBII
Ranger Custom
Truck of Month
982
UT
The motor and tranny together? Yes, but you need a serious angle and a good cherry picker. I just did the same thing, a few weeks ago.
I removed the radiator itself and the engine fan, and then the combo will squeeze out.
Junk Collector
Truck of Month
4,839
Rapid City SD
It's definitely doable, I pulled a 2.8, A4LD, and t-case out of a BII a couple months ago without separating them. It helps to have the front wheels of the truck on some boards so it's a little higher, and someone underneath to push on everything.
