Mikejsmith1985
- Apr 22, 2015
- Reaction score
- 0
- Automatic
Hi guys, I'm here as a last ditch effort to figure out this issue before I try a gasoline conversion. The motor is in a boom lift and the manufacturer is out of business and I'm struggling to find support anywhere. The motor should be solid mechanically the last couple times it ran everything was quiet and silky smooth and then it just quits. No sputtering, no hesitations, no rough idles just stops like I turned the key. I can't get it to start again, the issue is it won't fire it will turn over but no spark. There isn't an obd port to hookup and look for codes. I was hoping maybe someone has seen this in a gas powered motor and could suggest if perhaps there is a commonly faulty sensor or something. I know a bad sensor can cause some crazy stuff! If I can't resolve im going to try buying an old ranger and swapping the intake and fuel systems over with a ranger ECU and see if I can get it running again.
Thanks for any suggestions!
