- Apr 7, 2008
- 26
- CA
- Ford Ranger
- Engine Size
- 4.0L V6
After installing the new leaves I find that my one piece driveline rubs on the middle most crossmember so that will need to be addressed, but for now about 200lbs of scrap steel in the bed allows it to be driveable.
Rear shocks seem a bit too short by about 2-3 inches I'll have to take them off and measure for my new ones next week and possibly look into limiting straps (pulling apart some expensive shocks isn't my forte).
Still haven't got around to putting on my new braided stainless steel SJ brakelines up front, note the droop in the one picture has pulled it taught (not good lol).
Front shocks seem long enough, front suspension is about at its capabilities in last picture.
Current setup still surprises me and I am still debating if I should even mess with Early Bronco components for the sake of flex on a truck that will pull DD duty in the fall. The Early Bronco stuff is so temping, but it might be more trouble than its worth at this point in my life. Still going to order some of those James Duff Coil buckets when they are available just to have on hand. But I'm thinking I will acquire the parts in a "slower" fashion and plan for the EB flex setup to be completed NEXT summer...that gives me ample time to collect:
>EB coils (correct ones that is the first time)
>EB pads modified for TTB usage
>Modified SJ radius arms to accept dual shocks
>4x Bilstein 5100's
>StoneCrusher or SuperRunner steering setup, or possibly custom one based on the StoneCrusher setup only with TRE's instead of heims.
> and any misc hardware and extras that will be required (bolts, steel plate for tabs etc.
What I am going to do is the following (at least for this summer):
Modify my current coil buckets to accept the F250 shock tower mod,
run some long shocks, and go to Skyjacker 6" drop brackets as I need those anyway....then graduate from Tuff Country 4" coils with washers to Skyjacker 6" or 8" coils. Relatively bolt on, minimal down time, with no modification to the current steering setup while still providing a fairly nice ride on road with a fairly flexy (but not record setting) ride off road.
>4x Bilstein 5100's
