Product Test: 3M Headlight Restoration kit
LearjetMinako
12
Moore, OK
2.3L 140ci
So with my new job, I gotta start driving to work at 2:30am in the morning. And naturally with alot of vehicles, my headlight lens are not the clearest. I have used scotch-bite pad and chrome polish. But its kind of murder on the fingers. So when I saw 3M made a Headlight Restoration kit, it was something that I should try. And once again, naturally YouTube.com would have something on it. Even better, its "Two Guys Garage" and they using the 3M product on a Mazda B-series truck.
http://www.youtube.com/watch?v=BCDn-AYDeg4
LearjetMinako
12
Moore, OK
2.3L 140ci
The finishing results:
It took only 1 hour and the 3M kit costed less than $25 with tax from Advance Auto. The results are abusolutly amazing. If your headlamps are dull or yellowing. I extremely recommended this restoration kit. One kit does one vehicle.
The proof is in the photos:
Prep work and before shots.
Passenger headlamp is done.
See the difference.
All finished.
Now some may note that the driver side lamp is not as clear as the passenger. It is clear, it was just the worst of the two. Also, the kit only includes 1x P-8000 grit disc. Which is the 1x disc that really makes them clear. It kinda of wears out on the next lens.
Some extra steps to ensure good quality. Blow off the lens each time you replace a disc. Before using the P-8000 disc, wipe lens clean with a dampened cloth. And don't be afraid of using a little extra polish. 3M said dime size. Go with quarter or half-dollor size. Lastly, TAKE YOUR TIME. Don't rush. Go light press with the sanding and keep the disc moving back & forth across the lens.
Downey
Muncy, PA
nice man my g.fs mom wants me to do this to her jeep
Ranger4657
Loveland Colorado
5.ohh nooo
how long does that last? ive used cleaner wax and a buffer before but it comes back after like a week or two.
LearjetMinako
12
Moore, OK
2.3L 140ci
I do not know. I just did it today. I would think for the climate in this area, maybe a year or two before the dulling comes back. Since thats about how long even new vehicles last before dulling occurs.
tony314
Firefighter
12
St.Louis Mo
Outstanding work. Looks like that kit is A-1 stuff. Might get that and use it on my wifes car soon.
ZMan
MTOTM Winner
406
Medina, Ohio
Ford Rangers
4/4, bagged
Looks pretty good!
Since I'm a painter, what I did for my Buick headlights was wetsand them with 1000 grit paper, and shot clearcoat on them. They look awesome, and stay that way because now they're protected.
OilPatch197
7
But will this work on POS 2nd gen Ranger lamps? (the ULTIMATE test)
(they must have all came yellow from the factory, surely have not seen one that was clear!)
IMO, we went backwards when we sacrificed durable GLASS lenses for fashion plastic!
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Does that kit give you anything to coat the lenses with afterward? I ask only because the factory puts some kind of coating on them when new, which invariably lasts anywhere from 5-8 years, then it weathers through. Subsequent polishings afterward never last more than 3-6 months before they get noticeably hazy again (at least out here in the desert southwest anyway)
pocket-rocket
Elkhart, Indiana
4 cyl.
I use the Meguiar's PlastX with my 6" buffer and follow up with clear coat.
OilPatch197
7
We call it a Hard coat, it is basically a baked-cured on clear coat(applied by robot sprayers) then you have lexan, and on specific vehicles have a anti-haze coating on the back.
LearjetMinako
12
Moore, OK
2.3L 140ci
The last step is to apply a polish with the foam disc. The polish agent may contain some kind of protective, but I'm not 100% on that. If further protection is something you want, most auto parts store sell clear coat paint in a spray can.
I'm going to give the product a try 'as is'. And see how long they do last. If they dull again shortly, I will do it again, but with clear coat as the last step. I'm also going to try the 3M kit on my dad's Buick Regal. His headlamps have a yellowing to them and can be much improved after the restoration.
triumphrider-1
14
Port Huron, MI
Ford F150
3.7L
The last time I polished mine I also waxed them, worked great.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Yeah, I tried clear-coating mine, didn't do anything to stop the haze (the clearcoat itself would then get hazy lol). Then it started flaking off some as well.
Is this "Hard Coat" stuff available to the public anywhere? I have no problem popping the lens apart and "baking" it in an oven at low temp if that's what's needed to make 'em exactly like new again :)
OilPatch197
7
As far as I know, it comes in 55 gallon drums, from a optical coatings chemical specialist, probably a proprietary trade secret, I would say no.:sad:
