Power Window Wiring
cormchar
Guest
Hi guys,
I want to wire a power kit on my truck and I need to wire the power to an ACC wire or to a wire that the unit will turn off when the truck if off. Do you know which wire should I hook this too? Should I use a relay for this? Where did you guys wire yours? I have a 2007 V6 Ranger. Pictures would be good too.
Thanks
martin
26
St Bruno, Quebec
1991
There's usually an acc tap on the fuse box.
Seabiscuit
Phoenix, AZ
Connecting to the fuse box can be tricky. Run a wire, include a 20 amp fuse from your battery. The wire from the battery and power window wire include a relay so the power is only used while your truck is started. To power the relay I ran it from the ignition start which connects to the radio.
