Power Inverter Install
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
215/70-R14
I posted on the Bronco 2 forum a while back about installing an inverter. Got a few responses but updated the other day and haven't gotten any feedback so I'll try here.
Has anyone installed a power inverter in their Bronco 2? If so, where? I decided to go with a 2,000 watt inverter, plenty of power for anything I'd really need to do out in the field. Trouble is I'm having a heck of a time coming up with a location to mount it, that won't be in the way of anything else. My bronco 2 has the little storage boxes on the sides but the inverters are too large for those so there went my idea of turning one of those spaces into an inverter box with vents. Thought about under the back seat...yeah no room under there either :(.
I have the cables already and a fuse & fuse holder for the inverter, just need to come up with a good location that the inverter won't get damaged by cargo or kicked, stepped on, etc.
Doofy
7
Alaska
Shit Happens...Then You Die.
I installed my 2700 watt behind the rear seat in my 91 F350 Crew Cab. Mounted it to he rear wall on it's side. When using the inverter I fold the seat forward to aid in cooling.
I would install in the most out of the way spot possible and add a safety cage if needed. Use the largest cables possible from the battery to the inverter and try to get it as close to the battery as possible.
I've used mine to power floodlights, run electric chainsaws when not in the mood for loud gas ones and also to run the heaters in the house during an extended power outage at -20 degrees. With large loads, You almost need a throttle to increase engine speed some. Oh Yes, I also had to get a full sine wave unit in order to run my heating units in the house because of their electronic circuit boards.
I have since added a 2000 watt Honda inverter generator to my back-up repertoire. Damn near ready for the apocalypse!
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
215/70-R14
I have 0 Gauge cables :). Those should be plenty large enough. The trick is getting the cables ran out of the way, as well as mounting the inverter where its out of the way, yet has plenty of air circulation. Wish those storage boxes in the sides in the back of the Bronco 2 were larger, one of those would be perfect, and add some ventilation and a fan if needed, but of course they're nowhere near large enough, unless you just want a little 200 watt inverter LOL.
I have amateur radio gear installed so I can imagine at some events having some 120V juice would be a good idea, so the inverter will be a huge plus, probably won't be used often but nice to have for those few times I do need it.
Thinking maybe mounting on the back of one of the rear seats, only trouble with that is, if I lay the back seats down for cargo. Not much in the way of options I can see right now, but I'll certainly figure something out.
Spott
21
SE Idaho
I have mine mounted under the driver's seat, with the outlets and controls facing the door. When I need to use it, I just open the door and run an extension cord out.
8,372
Just mount Duplex 120vAC outlet in the storage box, in plastic back box
Inverter can be put in engine bay, even front side of rad support if you cover it
Run extension cord, of proper gauge, 120v(16amps) so smaller/cheaper wire can be used :), to duplex outlet
Put extension cord inside plastic conduit in frame rail to protect it from road debris
The larger gauge 12volt wires from battery to remote mounted 2,000 watt inverter costs alot, and still needs the protection from road debris
Use rubber grommets where ever wire passes thru metal
Doofy
7
Alaska
I ran all my 00 wire thru 3/4" heater hose where it came thru the floor and anywhere it could rub or be damaged. I don't leave the + hooked up to the batteries all the time...I just use a wing nut on the battery stud.
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
215/70-R14
Great ideas, not sure about mounting under the hood, it gets pretty dang hot under there, and already very limited space.
Under the seat sounds like a good easy access yet out of the way option and pretty descent airflow. Still maybe having the outlets themselves remotely mounted in one of the storage cubbies would still be nice as most likely the most common area of needing the power would be in the cargo area anyhow to run tools and that type of stuff.
The cables I have are from this source:
http://www.ebay.com/itm/0-GAUGE-POWER-AMP-KIT-AMPLIFIER-WIRING-INSTALL-6000W-PRIORITY-SHIPPING-TODAY/252361556263?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
Doofy
7
Alaska
Pretty sure I used fine strand 00 welding cable that had a thick rubber covering instead of the thin thermoplastic covering. I used the absolute largest cable possible because my run was about 15 feet. All my fuses are on the inverter.
Maybe I should add a mega fuse at the battery also.
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
215/70-R14
Looking around more I may do an under seat mount. From the chart I found the 0 Gauge cable will be fine anything more than about 12' will require 00 gauge. That's also based on a 5k inverter, so having an inverter 1/2 that capacity the 0 gauge cable is perfectly fine, however I may go with the larger cable anyways like you did, I'd rather only run the cable once. I have an ANL Fuse block and a 350 amp ANL fuse.
The only thing I'm trying to figure out is where the best location would be to put the wires from the battery into the cab? Doubt there's enough room to run them through the firewall and down behind the trim along the floor so thinking I may have to sink to drilling a hole in the floor :(.
Doofy
7
Alaska
Your plan sounds good to me. My plow truck is a beater so I didn't mind running up thru the floor. You can seal it up nice and tight. Since we get so cold up here and wire and stuff gets so stiff...I use 12ga extension cords that remain pliable in cold weather.
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
215/70-R14
I'll look around better in a couple days when I have some time off and see what options I have for cable routing. If I have to go through the floor I'll try and do so in a location that can easily be sealed back up, and easily accessible. I'm thinking if I run through the floor about running some sort of tubing through the hole as a conduit, and make it large enough to accommodate any potential future wire needs.
