Power Capacity
45
Wenatchee, WA
Ford Ranger XLT
31”
Hello, I’m looking to put some KC Apollo pro lights on my Ranger, and was wondering if I would need to do any upgrades to the power system for them. The ones I was loookign at have 2x 100W bulbs. I’ll link them below.
thanks
KC Apollo Pro
https://www.kchilites.com/6-apollo-pro-pair-pack-system-black-kc-151-spread-beam.html?utm_source=google&utm_term=&utm_medium=&utm_campaign=PMX.Lighting&utm_content=&audience=&gad_source=1&gclid=Cj0KCQiA5fetBhC9ARIsAP1UMgEzYaCAlP2JjK-_ZpDSvBiqApiUtK3RbprWhYGV6ivi9k2YcAoKTDwaAsOIEALw_wcB
RobbieD
2.9l Mafia
3,558
Georgia
The kit that you've linked includes a relay, and it should include wiring instructions on how to connect what comes in the kit.
Unless you have a lot of other added electrical accessories, the truck's electrical system should handle these lights. You do need to use the relay.
KC used to be a good manufacturer; I'm assuming that they still are. It looks like what comes in the kit is all that you'll need.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,543
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
If you're buying that kit... the wiring that comes with it should work.
Your current vehicle wiring should be able to handle any loads on the low side of the relay. The higher current side of the relay should have the appropriate sized wire to handle the bulb load.
45
Wenatchee, WA
Ford Ranger XLT
31”
Ok, thanks. I had figured that the engineers at KC had it covered and made sure the included harness could handle the power, just wanted to check though. And I don’t have any other accessories drawing power.
sgtsandman
Aircraft Fuel Tank Diver
12,743
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
The lights only draw 16.6 amps as a pair but like the others said, use the harness that came with it and make it take the load of the lights. It shouldn't take much to switch the relay on and off. Make sure you have a fuse protecting both sides of the wiring. 20 amps for the load side and whatever the relay needs to have enough amperage to switch it on and off.
