Yes, the solid windows interchange with the pop out side windows.
The hardest part is drilling the holes in the interior side panels, for the latch.
Remove the all the trim panels to get to the inside of the windows.
Remove the nuts on the back of the windows, and gently, but firmly push out on the window to slowly break loose the butyl sealer.
To get the remainding butyl off the window opening, I find making a little ball of butyl, and sticking it to the butyl on the cab and pulling away quickly, works best.
The pop out weather stop just goes in place (make sure the seam is at the BOTTOM of the window).
I believe the pivots rivet to the B pillar, before the side panel goes back in place, Nd if I'm not mistaken, the holes are there, or marked.
Then, like I say, marking and drilling the holes in the side panel for the latch is the hardest part, you'll just have to look at it.
