Planning on rebuilding my 89 ranger motor
riss6270
ranger
I have a 89 ranger with the 2.9l 5 speed 2wd. I just purchased a new well 03 ranger and have had very good luck with ther 89. I dont want to sell it bc it gets very good mpgs. It has a little over 200k on it and just seems like its running out of life. I was thinking about rebuilding the engine. I have never done this before but i think im more than capable of doing it. I just dont now if it is worth it or not. Does anyone have any thoughts and or pointers if i should go through with it. I would spend up to 800 or 900 in doing the rebuild. Is it possible to do it for that amount??? WOuld it be better to get a motor from the junk yard for 350 and rebuild that one and then swap it??? Any thoughts would be great. Also this is my first post so hello to everyone. I have had my 89 ford ranger since i was 17 and just purchased the 03 a mth ago. I love the rangers. The best on the road. I do have to say i am a little shocked that im getting 12mpgs in my 03 ranger 4.0 fx4 4x4 5 speed man. Thought i would be getting a little bit better.
doorgunner
Lab Rat for V.A. hospital
MTOTM Winner
2009 Truck of The Year
516
New Orleans (8' below sea level & sinking)
350+1
N/A
3/4
23570R15
JESUS Loves Ya!
Welcome! Maybe you can do a good tuneup instead of rebuilding the engine/chek the catalytic converter to see if it's clogging up/add headers/etc to get more pep out of it....(it's not healthy to rebuild an engine that still gets good gas mileage)....just use a couple hundred of that $800 to beef-up the 2.9 & use a hundred to tune up the '03 to get better mileage...
my .02 cents....
NEVERDONE86
Rio Rancho, NM
2.9l
:agree:
I JUST REBUILT MINE BECAUSE IT LEAKED REALLY BAD AND GOT HORRABLE MPGS. I WOULDNT REBUILD IT JUST DO A FULL TUNE UP AND RUN IT.:icon_thumby:
O AND WELCOME TO TRS!
doorgunner
MTOTM Winner
516
350+1
N/A
3/4
23570R15
JESUS Loves Ya!
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
Drop a 4.0 in it
riss6270
ranger
Country...
i dont think i can afford to put gas in 2 4.0l engines. So after read the pose from doorgunner i think im going to do a hell of a tune up. If im doing a tune up would it be worth doing rings and all of that? What would be ideal for a tune up?
martin
26
St Bruno, Quebec
1991
At that mileage it's just broken in, if it's running well and not leaking like a sieve, tune up and drive.
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
When you say piston rings, that is far beyond a reg. "tuneup"
fyre82
Firefighter
6
Lake Almanor, Ca.
2.9/4.0
9" on the 2000, 6" on the '88
265/75/16, 31x10.50x15
The memories of a man in his old age are the deeds of a man in his prime
Seems that even with parts from Rock Auto it's almost a grand to rebuild just in parts, that's without head and block work.
That said, its about a grand for a warranted rebuild, or should I say was when I replaced mine a few years ago.
So, like mentioned, if it doesn't leak, too bad, rattle like a can of rocks, then tune it, plugs, cap, rotor, wires. Pull codes to see if there are sensor issues and go from there. A little goes a long way with a 2.9.
Good luck
Rich
doorgunner
MTOTM Winner
516
350+1
N/A
3/4
23570R15
JESUS Loves Ya!
Country...
A. spark plugs
B. spark plug wires
C. distributor cap
D. distributor rotor
E. fuel filter
F. PVC valve
G. air filter
H. oil & filter
I. fuel system treatment(fuel injector cleaner--1 bottle added to next tank of gas)
J. but NOT a ring job!
riss6270
ranger
Ok. So I'm going to be buying the stuff tomorrow for the tune up. I do have one issue with the truck. The oil pressure is very low. The gauge will go from the n in normal to almost nothing and there is a slight ticking sound when I start the truck. Usually goes away after 5 min or so. But for the most part it runs fine. I will post pics of my two rangers when I figure out how on here.
riss6270
ranger
One question. Where does the PVC valve go? Never replaced before
riss6270
ranger
Pcv ...... Stupid auto correct
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
I get 21 mpg on the highway in my B2. 16 city. My 2.9's have never got great mileage
