Pizza cutter options
curtis73
6
Harrisburg, PA
Mazda
I'm looking to put some pizza cutters on my 94 Fordzda Branger.
Long story short, I'm looking for skinny options. Stock size is 265/75-15. Currently has 31x10.5-15 (same basic size).
I could keep the 31" diameter, but wouldn't mind adding some diameter to make my speedo more accurate. I am used to being off by a few mph, but anything up to 32" would close up that gap. Right now on the highway, at 75 indicated I'm actually going 71-72 GPS. No biggie, just letting you know that there is room to go bigger.
I love pizza cutters, but it seems that the A/T tires out there range from fat to obese. You can do wide or extremely wide. Any of the skinny options are usually E-range (215/85-16).
Goal is 80% street/rain/snow, 20% very light off-road, almost never mud/sand. I use the 4x4 to get in to a couple hunting camps and for heavier snow, which puts me squarely in the A/T category unless you can think of an A/S that could fill the bill. I put about 20k/year on my trucks and loud tires kinda suck.
When it comes to wheels, help me narrow down some 16" and 17" options from the junkyard. I know the 5x4.5 pattern was used on everything from Dodge to Bentley, so if you have a suggested tire size, throw out some suggestions for donors for the wheel as well :)
Danno1985
105
MKE, WI
stock
stock
stock
For a true pizza cutter, you're probably stuck with E-rated, unfortunately. Check the Cooper AT3 LT out. At 235/85r16, it's only 43lbs - not horrible at all. I ran this size for many years on my 4runner and Tacoma; it's a very functional size if you can manage the stiff ride.
I like this pizza cutter.
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
No, this is a Next Generation pizza cutter.
You are Amazing. I don't know how you do it. It's like you knew he was gonna ask.
I have no job and no life. This is what I do with my day.
curtis73
6
Harrisburg, PA
Mazda
Ok, so after an exhaustive search I've decided to give up on pizza cutters. Instead I'm going to get some 16" wheels from an 05 Ranger and do 265/75-16. I figure I'd rather put up with the wider tire than the E-range ride quality.
They have an overall diameter of 31.7". In your experience, will they rub with an otherwise stock setup? Stock tires are 265/75-15 which has a 30.6" diameter. It currently has 31x10.5/15 on it. Can't imagine an extra inch should kill things, right?
I also realize I will probably have to machine the center bores for the hubs in the front, but that's not a worry.
You should be OK. I'm running 31s on a 1st gen, which has smaller wheel wells, and I don't rub except on extreme turns, and I only trimmed a little.
gw33gp
538
Costa Mesa, CA
4.0 SOHC
33"
I ran 32" tall tires that were 12.5 " wide on my Ranger and had very minor rubbing. The 265 are more like a 10.5" wide tire. I know your 94 is somewhat different than my 02 but I think it should still work if you have 4WD. If you have 2WD it will sit lower, if it is still at factory height. This could be a problem.
I run 33" x 10.5" tires now with no problem. They did rub the front mud flap mounting brackets at near full turn initially but I bent the brackets a little and have not problem anymore. I have a 1.5" torsion bar crank lift and I am sure that helps a little.
curtis73
6
Harrisburg, PA
Mazda
Thanks all. Will I have to enlarge the center bore on the later Ranger wheels to fit my old school hubs? I did convert to Ford manual hubs which I think are the same diameter as the busted automatic hubs I took off.
