pinion shims......
jarfly
So I got all my bearings and all of that and just need pinion shims to set the preload. I have looked ever were ifor shims that aint 50 bucks. wheel the jeep ones work? I found them for aorun 10 bucks or so... please help really want to get my 5.13s in.
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Pretty sure Jeep pinion shims will work, but NOT the carrier shims (unless you already have some carrier shims, you'll need those too).
$50 actually sounds pretty reasonable for a TTB D35 setup kit. I've seen them over $100, even without being a master kit (no bearings, just shims).
dla
You can get a pinion shim kit for $12. Or you can beg a set of shims from a shop that does gear swaps and return the ones you don't use.
jarfly
Ok so anyplace were I can just get shims on the net? What size is the ones for the 35? Iv all ready got new bearings and the seals. Trying to find someway to get out of paying over 100 bucks for small metal disk.
jarfly
Yelp just found them I think I'm just goin bite the bullet and get them
dla
Seriously? You're gonna spend $100 because you can't find the Yukon $12 shim kit? Or because you're too lazy to ask for some from a shop that probably has a mountain of them?
Or maybe I misunderstood...
jarfly
Were can I get a yokon kit for a dana 35 with the pinion shims and carrier shims. 60 is the cheapest I can find for a dana 35, I have yet to be able to find the measurements on here to cross match to another rear.
The 8.8s are all the same I think, can find them pretty cheap.
And on the shops around close most of this small town has closed.
jarfly
Ok need this cleared up I have seen people talk about these cheaper kits to do this yet have seen a part number or link. Closest I can find is pinion shims but no carrier shims. Assume I do need the carrier shines as I think the 5.13 ring is thicker. The 8.8 I can find pretty cheap
