Piecing lift together
VBredneck
Centreville, VA
Mazda
I'm trying to gather some information and/or opinions about what the pros and cons would be of piecing a lift together instead of just buying a straight up kit.
I've got a 97 B4000 extended cab and I want to go up as high as I can without getting that vibration in my driveshaft so I was planning on 4-5 inches but I've got that 4.0L V6 which makes me fairly heavy in the front. What I was thinking of doin' was gettin' a front bracket kit from Superlift or a RC or TC 4 inch lift and using 6 inch SJ coils and extended radius arms but I don't know if the coils for a six inch lift will put too much strain on brackets that are set up for a four inch lift. I figured the 6 inch coils with a 4.0L V6 and a lift designed for 4-5 inches would actually put me closer to a true 4 inches of lift than I would if I used coils for a 4 inches lift.
The truck's a 2WD so I don't plan on doing a whole lot of 'wheeling but I live on the Outer Banks (VB-born though) and if I can figure a way to weigh my rear end down enough I do wanna get it out there on that beach occassionally.
Any thoughts/ideas or "just go buy a SJ lift"-s are greatly appreciated.
wahlstrom1
J-man HD Mech
2011 Truck of The Year
Forum Staff - Retired
21
Edmonton Alberta
You'll be fine using 6" coils with the 4" lift. It's quite common and allows more ground clearance than using the 6" holes on the brackets.
-andrew
VBredneck
Centreville, VA
Mazda
Cool, thanks. I thought I had read that somewhere on here at some point I just couldn't find it. Perciate it.
JFA_Spyderman
Law Enforcement
Whidbey Island, Wa.
Yo,
From what i have read, Skyjacker makes the strongest parts. And actually they offer 4 different 6" lift kits depending on your plans for wheeling and budget. All with 6" coils, some with radius arm drop brackets, some with new arms. Some with blocks, some with leaves too.
VBredneck
Centreville, VA
Mazda
Yeah, I saw those different kits on their new and "improved" site. I don't really want a six inch lift, just the six inch coils. And I'm a cheap bastard so that's why I was thinking of just getting the RC 4 inch kit and then picking up a pair of SJ 6 inch coils. I figured since I won't be doing a whole lot of crazy wheeling I'm less inclined to worry about getting the highest quality brackets possible. Stupid, I know, but like I said, cheap bastard.
JFA_Spyderman
Law Enforcement
Whidbey Island, Wa.
Yo,
As i understand it, those 6" Skyjacker coils are going to give you 6" of lift regardless of which hole or mounting bracket you use. If you are only looking for a 4" lift, i would go with a Skyjacker or James Duff kit. Even though you dont plan on a lot of wheeling, it's nice to know you could if you wanted.:D
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
No, the 6" SJ coils only come up to about 4.5" lift on a big Supercab V6 truck (SJ really should spec different (longer) coils for the SC trucks, but they don't).
I don't see you saving much (if anything) piecing together a lift though (unless you are getting used brackets or something).
I'd just get the SJ Class II 6" 2WD kit, and just mount the axle in the upper (4") bracket holes.
JFA_Spyderman
Law Enforcement
Whidbey Island, Wa.
Yo,
Ohh i see. For some reason i thought they spec'd them out with just the 4.0 supercab in mind.
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
It seems like they must've originally prototyped their lift on a 4cyl std cab or something, as that (or a BII) is the only vehicle that seems to get close to a true 6" lift without having to use a spacer under the coil. If anything, the SJ coils are slightly flexier than most other TTB coils though.
VBredneck
Centreville, VA
Mazda
Well, I appreciate the input.
Originally I was gonna get my hands on some used brackets; one of those I know a guy who knows a guy type things. But I actually talked to the guy I'd be getting them from today and he was some crazy, drunk, don't-give-a-f#*k 'necks so...I don't trust him much and, needless to say I won't be picking up those brackets.
I guess the Class II SJ is my best bet, maybe with some coils for an F150. My truck needs some stiffening-up anyhow.
Thanks guys.
