PCV valve info
RangerVet
34
Kingman, AZ
FordRanger Edge
From here on down it's uphill all the way!
I decided to do some maintenance on my '05 2wd Edge. One of the things was to replace the PCV valve with a new one. For the most part I use NAPA as I get a Veteran's discount there.
My first problem was to source a new one as they list 3 different styles for the 3.0. I had to bring in the VIN for the truck.
The second problem was to find the dang thing on my Ranger and then to remove it. I do admit to being a GM guy so it messed with my mind that I had to unplug a sensor from the old one (what is up with that?) and then I had to pull turn it counter clockwise in order to remove.
The metal clamp was installed on the hose so that the tangs were in a position that it made it impossible to remove with any of the tools I have in my toolbox. I used a rotary saw with a small disk to cut through the original Ford part.
I took a couple of pics to show the part and the location where it is located. Follow the chrome pointer/magnetic pick up thingy to see the hole. I would advise bringing some padding to lay over the sharp engine parts .
47679
47680
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
8,374
Peanut gallery ^^^^
Any way yes these can be a pain to swap out the first time
And the electrical connection is for a Heater inside the PCV Valve, not a sensor, just FYI
In colder climates the PCV Valve can freeze up from normal condensation in the engine
That's why they wanted the VIN
This type uses heater hose splices: https://www.taurusclub.com/attachments/pcvheat-jpg.200906/
In my opinion the electric were best, less chance of a coolant leak, lol
Just be happy you don't have a 2002 and up 2.3l Ranger, have to take off driver side wheel and go thru inner fender to get to its PCV Valve
RangerVet
34
Kingman, AZ
FordRanger Edge
Thanks guys. Former owner of several Corvettes too just to fan the flames. I was also a stringer for Corvette Enthusiast Magazine until they stopped publishing.
rusty ol ranger
2.9 Mafia-Don
7,715
Michigan
177 CID
Its alright. Im a ford truck guy but love mopar performance.
8,374
I drive GM cars and Ford trucks
The El Camino was the only GM "truck" worth owning or driving, but GM cars are consistently good
Ford can't make a car, don't know why, they make great trucks, just can't get the "car thing" down, consistently bad
A Ford car is like a GM truck, not worth taking a chance on either
IMO, Dodge is hit and miss on cars and trucks, there are really good ones and really bad ones, not consistent, you have to wait 10 years before buying a model if it holds up OK :)
Eddo Rogue
2,505
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
I was told GMC= Gay Mans Chevy
sgtsandman
Aircraft Fuel Tank Diver
TRS 25th Anniversary
12,811
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Whatever it means, GMC is for people that haven't got it that they are paying more for GMC branded parts than the equivalent Chevy part. Whether the vehicles themselves cost more or not, I can't say but the parts prices have been gripe for years. Thier answer when asked why? "The parts are 'hand picked'". What a load of crap, though I wouldn't be surprised if Lincoln does the same thing for their parts compared to an equivalent Ford part.
racsan
4,510
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
good greif, I thought pvc valves were (still) just stuck in a valve cover grommet with a rubber hose at the top. (or on a 2.3 lima, in the middle of a line going to a crankcase breather under the intake)
Yes, GMC is just a overpriced chevy, kind of like mercury was a overrated overpriced ford with some different trim parts. It might of meant a “tougher truck” back in the ‘50’s , but wasn’t everything built pretty tough back then?
Eddo Rogue
2,505
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Maybe its stands for Greater Marketed Crap.
