Noflers
- Apr 13, 2015
- 0
- Ford
I was thinking about how to secure my bed to the frame because the bed is rusted out around the two bolts closest to the bed. I decided I was going to send the mounting bolts through a 48"x8"x3/4" piece of plywood. This brought back memories of when I wanted to turn my bed w/canopy into a 2-3 person lounge with custom fit cushions around the sides from wheel well to wheel well. This would be perfect for a temporary fix, and my dream lounge!
I then became completely obsessed with the idea. I took all the necessary measurements and started to figure out the materials I was going to need.
It's going to need a slanted back support to the cab wall side. I could have two small tables by building boxes over the wheel wells. Of course I'll have to put a hinge on the top to I can use it for tools, or whatever will fit since there won't be much space in there. The slanted backrest won't be able to go all the way across the width because I definitely need a cushion that will fit flush with the tables and up against the backrest. Oh, and if all the walls are going to be finished so nicely I might as well cover the ribs of the bed floor with a piece of wood and throw a nice thick piece of foam on that with some zebra print upholstery wrapping it.
Okay, kidding about the zebra print, I'll probably a deep blue to match the truck.
While I was at the local Fred Meyer, which is being remodeled I noticed they were selling 3"x30"x70" *foam padding for $20 each (half the price of the padding at the fabric store. I decided three would be plenty for the job. Next I went to Parr Lumber and picked up a sheet of 1/2" fir plywood and a 2"x4" and had them rip out my rough cuts.
I plan on doing this over the next couple weeks and thought I'd start a build thread on it. Hope everyone finds this as exciting as I do!
