Part ID help?
Mbrockman5
2.9L
Can anyone tell me what this part is?
Sent from my iPhone using Tapatalk - now Free
Die.Fledermaus
4
State of Jefferson, USA
2.0 (4 Cylinder)
0"
Normally that is the remote starter solenoid, but I doubt it is being used as one
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
That's what it is...and it looks like it is actually connected for basic starter connectivity...but usually they have a few more wires attached...even on an 88...mine has one wire on the positive side and three on the negative side...or vise versa...
Mbrockman5
2.9L
Ok. Thanks. If you notice the newly taped wire in the background..... Well, after yet another dead battery(parasitic drain somewhere), I went to jump it and I think it shorted out somewhere and that wire started smoking. After my battery recharges, I'm going to see if I shorted that solenoid out.
kimcrwbr1
46
maplevalley WA
2.8l
Disconnect the battery and pull the terminals off of the solenoid and clean good with a small wire brush. The large red wire on the left looks like it is almost touching the small terminal on the bottom of the solenoid, tighten it so it is pointed toward the left away from the solenoid, does it go to battery posative. You dont need to hold the camers so close! The wire that is taped does it go to the starter? You really need to clean up the engine bay and go through all the connectors and clean with electrical cleaner and use dielectric grease to put them together. Look for any bare,cracked or broken wires and repair as necessary. Sand all grounds metal to metal and bend the battery cables end to end looking for weak spots. The first thing I would do is blast it good with a pressure washer and let it dry good while cleaning all the connections and inspecting the wires especially around the exhaust manifold/s.
