WhiteBroncoII2WD
- Aug 14, 2007
- 1
- Delaware
- Ford
- Engine Size
- 2.9
I am in the process of repainting my Bronco II. Lord willing this will be the last time, someone took a screw driver to it. I had it painted Performance White, but I want to take it back to the original factory Ford white. Here’s my problems the paint code along with other important information is gone, the sticker was removed from the door. I’ve narrowed it down between two codes, 9M and 9E. If anybody has an 89 Bronco II that was originally white would you please check the code? 9E was called a Special White while 9M was simply called White. In the DuPont paint books 9M is listed for Rangers and Bronco II’s, but 9E is listed for Kentucky trucks only. I thought all Bronco IIs were made in Kentucky. Please, would you check your paint codes and see if the 9M is more common?
