P0446 Emission Control System Code
ochoam
6
USA
I have a P0446 code that I am unable to resolve. P0446 Evaporative Emission Control System Vent Control Circuit Malfunction.
Looking at other resources the code points to the vent valve solenoid. I confirmed the 20A fuse is in place and that the connector for the vent solenoid is receiving 12volts when the key is in the 'on' position. I did not see any obvious holes in the hose or connecter wires, but there was considerable rust and debris around (located in the midwest).
After replacing the vent valve solenoid, I am still receiving a P0446 check engine code.
Any help is appreciated, thank you.
ochoam
6
USA
My code will only come on occasionally, but due to the amount of charcoal that came out when I changed the valve I'm going to replace the canister as well.
Also never knew gas levels cause your emission system to check more/less frequently.
ochoam
6
USA
Replacement OEM canister from a Ford dealer was also leaking charcoal out of the box. Sounded like gravel wis in the box when I picked it up initially.
Round 2 of ordering a replacement will be with Rockauto.
Anyone have a 'fix' for charcoal coming out of the canister?
