Over Heating Issues
Screech1
Northumberland PA
1990, and 1988
2.9 (Both)
:icon_bounceblue: Hey guys haven't been on for a while, been busy. Wanted to ask if any of you guys might have some ideas as to why my truck would over heat :icon_confused:, it seems to burn through water. This is the second Ranger I have owned now with the 2.9 and they both have had the same problem, I don't understand it is it something with the motors or what. Am I missing something with this or what :dunno:, any help would be greatly useful. THANKS in advance for any and all advice. :icon_thumby:
jhammel85
Guest
How fast is it losing water? Any leaks at all?
I would run it and make sure the antifreeze is circulating. If the water pumps OK then I would look else ware..
Another thing to think of is a cracked head. If that was happening, There would be anti freeze in the oil and white smoke from the exhaust.
I hope that helps you get started.
Keith333
I have an 87 2.9L 4x4 and suffered with similar problems with mine a while back. Assuming there are no obvious (or even un-obvious) external leaks, try checking your oil filler cap for the dreaded "white snot" indicating there's an internal leak and water/antifreeze is getting in the oil.
