On a scale of 1 to 10...
Andy D
10
Marshfield MA
The Rat
4.0 OHV
to prevent Found On the Road Dead, Fix Or Repair Daily
I used Wonderbread instead of grease. IIRC it was 4 or 5 slices. Takes a while, but is cleaner than grease. Did it just to see if it would work. I used a washer and a dowel.And a hammer. :D
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
Cool, glad you found one :icon_thumby:
Lost Bushman
Lexington, SC
Well, at least wonderbread is good for something.
Sent from my Casio G'zOne Commando 4G, it's the John Connor of Smartphones. You cannot kill it...
Using Tapatalk.
Lost Bushman
Lexington, SC
Well, here it is....
Part numbers for future reference...
Thanks for all the help guys!
Using Tapatalk.
Totalled
Law Enforcement
Tumwater, Wa
8 rabid gophers
Looks like you'll have to source one from another 2.9L or 4.0L flywheel at a junkyard then if you can't find one elsewhere.
I went through this when I converted my Explorer to M5OD. You have to harvest the bushing from a 4.0 flywheel.
The 2.8/2.9 flywheels have a smaller hole that just takes the bearing.
Don't worry about the bearing in the crank. Leave it. I put it into the crank the first time until I learned about the bushing for the 4.0 flywheel. Then I added that when I put a new clutch in with another bearing, and it worked fine with the leftover bearing in the crank.
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
Now you got me wondering where mine came from when I did my 4.0L clutch swap... (unless it did come with either the clutch kit or the flywheel I bought) I know for sure I didn't have to go tracking one down. :icon_confused:
Lost Bushman
Lexington, SC
I bought LUK clutch and flywheel and it didn't come in there.
Using Tapatalk.
