Oil Pan, Stamped to Cast swap
1up
5
So. Calif
I asked this Question a While back. Now I have the Answer to post for everyone.
I'm dropping a 86 Merkur Turbo engine into my 89 Ranger, I was concerned about the oil pan as the Ranger has the cast aluminum pan with the 2 bolt bosses for the transmission bell housing, what I was concerned about was
(1) oil capacity and (2) structural integrity (trans mount). I was afraid the oil pump pickup would not fit due to the different design of the oil pan (the cast pan having a cavity at the rear or the pan).
Here's what I found, it was to easy the only thing that is different between the two is the oil pump itself, the pickups are the same, I just bought the pump for the 89 Ranger and switched the pickup, (I did not have my original P/U from the stock Ranger engine), the pump for a stamped steel pan has the oil pressure spring housing cast into the upper side of the pump putting it next to the pan rail gasket area, the Ranger pump has it cast on the bottom of the pump putting it in the pan, I found the cast Ranger pan would hit this cast housing area of the Merkur pump.
Problem solved, I know it might not be a big mystery, but I hope some one will be able to use this information.
Curt
ejholmgren
2.3L
So you only used the merkur pickup because you didn't have the ranger one?
1up
5
So. Calif
Correct, I did not have the Ranger pick up,only the Merkur p/u. I wanted to use the original Ranger cast pan and was afraid the p/u's were going to be different due to the different oil pan designs.
So what I found was the only difference between the to installations were the actual pumps, not the pickups, they remained the same.
Curt
now I'm off to figure out the wiring,...........there I'm totally lost...:icon_confused:
