oil filter adapter
Broncodude
Kentucky
is the oil filter adapter needed? can't I just screw the filter on to the threaded insert thats in my new block that I got? looks like the same size?
JoshT
1,784
Macon/Fort Valley, GA
Unless you just want your oil filter to hit the manifold/header I'd have to say yes that adapter is required. I know with my headers it wouldn't fit sans the adapter.
Broncodude
Kentucky
I'm wondering if the oil filter being directly on the block sideways would cause dry startups so to speak cause it might empty out being sideways??
enginepaul
12
Northern California
2.8
It should work as a filter would in any other sideways installation. It won't go back into the Ranger sideways; you'll need the adapter.
Natedog
5
CA
A filter that hangs down like the stock setup is the best way to avoid dry starts, otherwise the oil has much more tendency to siphon/drain back to the pan...not good. I don't care who's filter or what, that is my experience.
Totalled
Law Enforcement
Tumwater, Wa
8 rabid gophers
Run a good filter that has anti drain back (like a motorcraft, not a fram!) and it's not an issue.
