off road light what size fuse and relay
Broncojumper87
12
wichita Kansas
2.3 EcoBoost
Picked up some kc highlights for free from a buddy anyway not sure how big of a fuse and relay to use
Scrambler82
11
SoCal
Ford/EDGE
4.5" SL
WWWhhhaaattt !?!
33 x 12.50
You need to know the total wattage of the lights, then you can convert that to amperage and then you can pick the rating of the components to use to wire the circuit for the lights.
BUT... Based on 150 watts each or 300 watts total circuit rating here is a few numbers.
300w / 12 volts = 25 amps total draw.
A 30 amp relay would work fine but a 40 amp relay with a 30 amp fuse on the power load or to pin 30.
10 gauge wire if both lights are on the same wire or two 12 gauge wires.
The relay actuation circuit can be run from the main circuit panel, a 1 or 2 amp fuse to a switch, then to pin 85 on the relay.
If the lights are 100 watts each then total draw is 17 amps and the 30 amp relay with a 20 amp fuse minimum will work on the power pin.
Anything else you want to know ?
Broncojumper87
12
wichita Kansas
2.3 EcoBoost
I actually have a 40 amp relay and a 30 amp fuse left over from another project so that should work out fine the light's are 100w I believe they are the ones from autozone
Scrambler82
11
SoCal
Ford/EDGE
4.5" SL
WWWhhhaaattt !?!
33 x 12.50
Post up some pictures of the finished product.
Broncojumper87
12
wichita Kansas
2.3 EcoBoost
I tried to upload pictures of my finished for now b2 but wont let me load them from my phone?
