OEM Alcoa 15" wheels don't fit
allfordguy
Comox Valley, Canada
Ford Ranger FX4
I recently purchased a 2006 Ranger FX4 Off-Road. It came with 16" rims that I don't like and so did the homework and bought a set of Alcoa 15" rims off of a Level II Ranger. Should fit right? Wheels rub on calipers. Has anyone had this issue? What's the fix?
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
The fix is to use 16 inch rims. The 15 inch rims only fit the smaller 11" brakes, your truck has 12" brakes.
sheep herder
1,024
sheep pen
If it ain't broke, break it.
Or use a bigger hammer.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,509
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I had my 15" Alcoa's on my 06 Sport 4x4... didn't rub at all.
Did They use bigger brakes on the FX4?
4.0blue98
I don't feel tardy...
701
Frederick, Maryland
4.0 OHV
Round
It was like that when I found it.
Just put them on, they'll self clearance... ;)
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
Uncle Gump
Token Old Guy
13,509
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I don't memorize spec's for these trucks so I went and had a look. 15" Aloca wheels were used through MY2007 FX4's.
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
Hmmmm interesting
Josh B
1,987
Oklahoma
Maybe the brakes are an other than stock swap as well
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
My 11" brakes barely clear my 15" steel rims. No way the 12" brakes would fit, especially with aluminum.
Grumpaw
1,504
Virginia
Ford Ranger XL
Stock
Stock
Stock 225/70/15
I don't count birthday's anymore...just happy to be looking down at the ground instead of looking up
If you pull up a 2006 Ford Ranger Brochure, it lists an FX 4 and an FX 4 Level 2 option. Both have listed different standard wheels for their particular packages. The FX 4 lists 16 inch wheels as standard while the FX 4 Level 2 lists 15 inchers as standard. The 15 inchers were not even listed as an option for the FX 4.
Possible this has a bearing on the fitment of 15 to 16 inch wheels to the OP and his Ranger.
Brochure does not list anything as to brake size.
But, if you google up rear brake shoes for a 2006 Ranger 4 x 4, it lists two sizes, a 9 inch and a 10 inch, which indicates there were indeed 2 different brake sizes.
Front disks and calipers look to be the same for both.
Grumpaw
Uncle Gump
Token Old Guy
13,509
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
They fit my 06 with 305mm rotors.
They even put them on from the factory in 06 as standard or optional for both versions of the FX4. I also seen that they could be polished or painted.
Uncle Gump
Token Old Guy
13,509
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I made a mistake above... I was looking at the 07 charts when the Alcoas were standard or optional on both versions of the FX4.
allfordguy
Ford Ranger FX4
Thanks for that info. That's the first I've heard that there are different brake sizes.
allfordguy
Ford Ranger FX4
That's the root of my confusion. The Alcoas were optional from 2003 to 2007. Some were painted but they were all 15" with 31 x 10.5 tires. Dirtman says that there are Rangers with different size brakes. News to me.
