- Jan 23, 2011
- 976
- Bronson Michigan
- Ford Bronco II
- Engine Type
- 2.8 V6
- Engine Size
- 2.8
- 2WD / 4WD
- 4WD
- Total Lift
- 6” skyjacker 2” body
- Tire Size
- 33x12.5
95 ranger 4.0. You know the ones with OBDII a year early. Had a miss that would happen once in a while. I noticed it a idle. It would be lower than normal. It would clear up quickly, then run fine. I rescued this truck after setting a few years following some vandalism. Been driving it for a couple months. I figured the plugs needed changed anyway so I put new plugs and wires on but it didn’t help. It’s my first non OBDI so I don’t have a code reader yet. Researching found it to be an issue for the 95 being I or II. Mine does not have non OBDII compliant statement on the emissions tag so I’m hopeful a OBDII reader will work. Mfg date 8/95. CEL is on as I have no cat and right bank has a broken connector on the O2. Today the miss never happened but my idle seems to stick on high. Never at a consistent level and sometimes it will come back down to normal but not always. Pulled the IAC cleaned it and re installed. Then it started whining when I accelerate. Put a new one in and now no whining but idle is still sticking on high. Can’t find any vacuum leaks. Gonna go try to read codes tomorrow. See what happens.
