O/D Light Flashing after 10 miles - 20ish min run time
ADrum707
Central Virginia
3.0L V6
I drive a 95' XLT 4WD 3.0L V6 - Trans code: 4R44E
Noticed a few weeks, maybe a month or two ago that my O/D light comes on about 20 minutes into a drive or after driving about 10 miles. It's very consistent and it takes HOURS off non-run time to not be flashing again when I start it up. When the light is flashing it's sluggish to start, and shifts harder than normal, ESPECIALLY when shifting into reverse. My gas mileage blows. I gotta get this thing fixed before I take it on a 1500 round trip.
I'm really hoping for anything but having to get a new transmission here...
I've seen possible solutions being the speed sensor in the rear diff, a sensor inside the tranny pan, other sensors on the outside of the transmission, etc.
What's going to be my best option here? What is the most likely cause?
:bawling: :bawling: :bawling:
Transman304
43
Morgantown WV
Chrysler PT
2.4
If you can’t fix it with a hammer, you have an electrical problem
Going to be a TCC issue. The computer is sensing a slip and upping line pressure to try and preserve itself. And then canceling lock up. How many miles, fluid level and condition?
ADrum707
Central Virginia
3.0L V6
Getting close to 190,000 miles - will have to check the fluid levels. Haven't had a chance to get under it since before my vacation last month.
What's TCC? Sorry I'm kind of a noob....
Transman304
43
Morgantown WV
Chrysler PT
2.4
Torque converter clutch.
ADrum707
Central Virginia
3.0L V6
Time to do some investigation, thanks so much Brad! :)
ADrum707
Central Virginia
3.0L V6
https://www.youtube.com/watch?v=1_Doh1quHo8
Do you think that ^^ this ^^ could very well be the problem I'm dealing with? Or could low fluid cause the issue as well?
Low fluid would indicate a leak right? I'm not seeing any fluid marks where I park it...
Thanks again in advance for your help! :) :headbang:
kimcrwbr1
46
maplevalley WA
2.8l
It probably has alot to do with foot feed or throttle position in relation to rpm? Have you checked the codes lately. A complete tuneup and diagnostic is where I would start it sounds like a compressin test would be in order as well the engine may just be getting old?
ADrum707
Central Virginia
3.0L V6
kimcrwbr1 - compression tested fine - this definitely seems to be a sensor issue, related to the transmission. Just didn't know which sensor to start with. TCC is a pain in the ass to change, but looks like it's the most likely culprit. It'll be getting a new engine within the next year - thought about getting a new transmission too.
ADrum707
Central Virginia
3.0L V6
Just checked the tranny fluid. Level was okay, color and smell.... not so much. :sad::sad::sad::sad:
