No Turn Signals or B/U Lights!
Mhfco6
Firefighter
87
Virginia
I just got done welding my new floor pan on the drivers side. I hooked the battery back up, put the interior and seat back in. Now my turn signals and back up lights don't work...Also I have an orange antilock brake light staying on. The hazards DO work. I feel like I might have not hooked an electrical connection back up after cutting the old pan and welding the new one.. The green arrows in the dash instrument cluster wont come on either, however they do work when the hazards are turned on. I've tried troubleshooting/replacing the 15a fuse.. I know it's not the fuse. Any suggestions?
If no one replies, I'm going to replace the turn signal flasher "relay". I will post my results.
Mhfco6
Firefighter
87
Virginia
I pulled the fuse panel and got in there with a test light today after work. I have no power to the turn signal flasher. The hazard flasher is working fine. Not sure why the reverse lights aren't working..
Mhfco6
Firefighter
87
Virginia
It's all fixed.. The flasher was bad AND there was a missing fuse (thanks to Haynes manual).. Not sure how it fell out unnoticed, but it completed the circuit. I'm still switching between manuals/diagrams to confirm which fuse it was.
little red ranger
Dyersburg Tn
if that link i set you works there are wiring diagrams on just about everything,,, it is a good or i should say great link to have,,, it has helped me and many friends,,, it goes from a to z for several years and models of cars and trucks,,,, save it and pass it around,,,very helpful link to have
Mhfco6
Firefighter
87
Virginia
Thanks buddy
