No power issue 1990 2.9lXLT...need advice
Maggrett
7
Pueblo, CO
Ranger XLT
2.9l
Yep, just changed the filter, correct flow.
ledgz1121
Parker, Colorado
BRONCO 2
What was the diagnosis or solution???Just bought a 86 b2 today and had a hell of a time driving up from NM. As soon as I got to a prolonged incline the truck would lose power struggle up the hill and could not maintain speed. It actually stalled out at Wolf Creek Pass. I'm new to the Ranger/Bronco2 and it sounds like you have or had a similar problem.
gaz
671
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (1½" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 33"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
@Maggrett ,
Your fuel pressure readings, the fuel system should hold pressure for days if not weeks; from what I read, yours is dropping off almost immediately after engine shutdown.
There are a number of things that can cause this. Have you done anything to the fuel system other than changing the inline fuel filter?
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,532
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Welcome to TRS...
I'm going to suggest you start a new thread in the 2.9L forum... and just start from the beginning with.
Maybe take a minute in the introduction forum... introduce yourself and share a picture of your new Bronco II.
Maggrett
7
Pueblo, CO
Ranger XLT
2.9l
Hello. I have not found a solution as of yet. Replaced the injectors, distributor, gaskets. Have not found the problem. I have a new fuel pump on the way in. My new problem is it running OK when starting, but losing power and shaking when warmed up. I'm taking a break from it before I go insane.
Maggrett
7
Pueblo, CO
Ranger XLT
2.9l
I am in Colorado, BTW. I've driven up and down Wolf Creek Pass in a snowstorm in my 1967 T-Bird (no longer have it). It was an adventure.
Maggrett
7
Pueblo, CO
Ranger XLT
2.9l
@gaz not previously. I have now replaced the fuel pump, filter, and injectors, IAT sensor and still no luck. It takes longer to start now than previously. The problem is now intermittent. Today I drove on the highway with good power. Once I turned around, it went back to limpy, gutless, slooow drive home. I can only figure it is some electrical connection that goes in and out. I'm determined to find it, but am getting exhausted from working on it all the time to no avail.
