No oil pressure
Tenper616
8
Florida
Mazda b2500
2.5 (4 Cylinder)
So I just replaced the engine in my 1998 Mazda b2500, put a remanufactured long block in it, got just about everything buttoned up and while filling the coolant up I started the engine to get the coolant flowing, let it run for about 5 seconds or so and I've got no oil pressure, at all, so I I shut her down, started it up again for a few more seconds, about three more, and no oil pressure still, how long should I wait on a remanufactured long block that has already been tested for oil pressure at the factory?
SenorNoob
620
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Five seconds sounds about right to me... How do you know you have no oil pressure? Light, gauge, noise?
alwaysFlOoReD
5,164
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Use the "clear flooded engine" procedure. Press the gas pedal to the floor. That shuts off the fuel injectors. Then crank away. If the motor tries to start then you have a leaking injector. Or stretched throttle cable.
rusty ol ranger
2.9 Mafia-Don
7,756
Michigan
177 CID
You hooked the sender wire up didnt ya?
Tenper616
8
Florida
Mazda b2500
2.5 (4 Cylinder)
I've hooked the sender up, yes, I hadn't thought of holding my foot to the floor, and no not on this motor there's not, and yes gauge sound and light
rusty ol ranger
2.9 Mafia-Don
7,756
Michigan
177 CID
Id unhook the coil wire/coil pack plug and crank it so that way you know it wont start. Even doing the foot on the floor it might start and rev to the moon before you lay off, not good with no oil pressure,
Tenper616
8
Florida
Mazda b2500
2.5 (4 Cylinder)
So I'm gonna pull the fuel pump fuse and the coil plugs, AND put my foot to the floor for redundancy reasons, and see if I can get some oil circulation today when I get home, I'll let everyone know what happens
55trucker
183
Oshawa, Ontario
3.0L
mild
It's a fair bet to assume that at the machine shop that built the engine they would use a mechanical pressure gauge & not an electrical gauge to monitor the pressure, try doing the same.
8,374
If valve train was not making noise then its a sender/gauge fault not low oil pressure
And don't rule out a blocked NEW filter, "new" just means NEVER EVER TESTED, not "it works"
Tenper616
8
Florida
Mazda b2500
2.5 (4 Cylinder)
It was making noise, as I'm sure I've mentioned before, usually I have the oil pump and prime it myself before installing it, but seeing as I dident install it and was told that the shop tested it all I figured it wouldn't need to be primed
rusty ol ranger
2.9 Mafia-Don
7,756
Michigan
177 CID
Id haul it right back to the shop
Tenper616
8
Florida
Mazda b2500
2.5 (4 Cylinder)
I did the work myself as I am a mechanic, just was looking for a way to prime the pump with out removing it, which I ended up doing, after I bench primed the pump it pumped up no problem, truck is running fine, few kinks to work through, has at least one vacuum leak I'll have to find, but other than that it's good
rusty ol ranger
2.9 Mafia-Don
7,756
Michigan
177 CID
Good to hear
No members online now.
