no drain plug??
04edge
ranger
so i go to change the fluid in my t-case and whadda ya know-- no drain plug?:stop:--guess i'll have to vac it out:bad:
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
May want to check under the round balancer on the lower left side. That is where mine was on my 2001 ranger.
MAKG
19
California central coast
Yup, BW1354 plugs are hidden behind the balancer. Four bolts gets that POS off.
04edge
ranger
thanks for the info!!:icon_thumby:
loaderman
do you need a puller to get balancer off----or just 4 bolts and thats it,
MAKG
19
It's just four bolts.
It's not meant to be difficult. This is maintenance.
Jspafford
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
I never did truly understand what the point of that balancer was. It didn't weight that much.
MAKG
19
It doesn't seem to do THAT much, but it's a harmonic balancer, much like the one on the crank. Big mass isn't important. Big moment of inertia compared to the shaft it's balancing is.
