Combs Customs
- Aug 8, 2007
- 2
- Age
- 38
- West Chester, Ohio
- 1993 / 1993 /19
- Ford / Ford / F
- Engine Size
- 4.0L / 4.0L /4.0L
I just got done putting my pedals in for my 5-speed swap. I hooked everything back up the way it was before. I have no brake, rear turn signals, or 4 way flashers. Fuse is good. The only things that happened during the swap was the P.O. had a piece of metal in the fuse for dome light for some reason, i hit it with my ratchet and shorted that fuse. Also, 2 wires came out of the multi-function switch plug. A brown/white stripe and a green. I tried inserting them both ways, i get no change either way. No meter or test light tonite, so im giving up for the nite. Any help would be apperciated.
*****FIXED******
Bad connection at the multi-function switch. Unplugged, tested for power, plugged back in and all is well.
*****FIXED******
