Newbie with 95 b2300 problems
Mgeiger1513
Jesup, Georgia
Mazda
2.3 4cyl
Hey there I'm a newbie, I've been reading this forum now for about a month now I have found it very informative. I just changed plugs, wires, cleaned throttle body, removed air muffler, & baffle, and installed new air filter. Afterwards truck ran great, like a new truck. However the next day it started stalling when throttled. Like it was choking down. I've checked everything I thought I might've disturbed with no luck. Any ideas?
Mgeiger1513
Jesup, Georgia
Mazda
2.3 4cyl
Any help would be greatly appreciated.
alwaysFlOoReD
5,132
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
On the phone I can't see your truck specs. That would help ....maybe.
Checked all vacuum lines?
Checked all electrical connections? They can be dry and hard to tell if connected properly.
Mgeiger1513
Jesup, Georgia
Mazda
2.3 4cyl
It's a 95 mazda B2300. The rpms are also fluctuating when I first start the engine, between 1000 & 1500.
swynx
9
lewiston idaho
Mazda
with the fluctuation in rpms, i would try cleaning the mass air flow sensor.
i would replace the fuel filter, there cheap enough and often is the problem. ive had a few vehicles where the fuel filter after about a year gets clogged, the vehicle will start and idle fine, but will not move at all. its under the drive side door on the frame rail.
i would make sure the plug wires are in all the way, they should click on and you should be able to push/pull on them as if they were locked into a socket (which they are)
does the 2.3 have a fuel pressure regulator? the one on my 4.0 was full of black gunk when i pulled it off and it gave me odd fuel related problems. might want to check that.
Mgeiger1513
Jesup, Georgia
Mazda
2.3 4cyl
I've checked wires and cables they are all good. I also have a fuel filter that I have not put on yet, does it take a special tool. I ain't sure about the fuel pressure regulator. I'll have to do some searching on that.
swynx
9
lewiston idaho
Mazda
i know ive worked on a 97 ranger and it had the special tool required. its like 7 bucks for a pack of 2-3, there circluar, and its a spring loaded design. on my 94 it just has the plastic locking clips, i put a screw driver in it and pry it apart. release the fuel pressure before doing so tho. i always close my eyes while wearing safety glasses tho.
the fuel pressure regulator should be on the passenger side of the intake manifold. look up a picture on google to get an idea of what your looking for. if you pull it off and the line on the engine smells like gas its bad i guess. mine was all clogged up with soot and black gunk so i replaced it.
Mgeiger1513
Jesup, Georgia
Mazda
2.3 4cyl
Thanks for your help. I'll let you know the outcome as soon as I get a chance to work on it. Thanks again
