Okay,
Sorry, i finally have a chance to get back to this project... Don't buy a house when your in the middle of a V8 swap...
Anyways.
So after buying parts, trading parts and learning (thank you guys!!!!) I have finally collected the parts i need
Small List:
Original Truck - 94 Ford Ranger XLT 4.0L Manual
Dornor Truck - 94 Ford Ranger XLT 4.0L Automatic (Swap Columns/pedals)
Donor Explorer - 96 5.0L w/ 31 spline rear diff w/ dics
- No Pats
- Fuel Return
- VSS in rear (which i'm swaping to run the
brain only)
Donor Tramission - 97 F-150 4.2L
- M5R2 Transmission w/ VSS Plug and starter (Which i'm swaping to run the stock 94 speedo)
- BW4406 TC w/ Shift Link
- Front / Rear Drive Shafts (convo u-joint) + not sure of the back.. but it looked okay, i'll see once everything is in place...
Purchased parts:
- L&L Motor Mounts (once i drop the assembly in, i'll inform how the tc fits) based on teh article in the tech pages, it'll b tight but do able)
- 164 T 50-once Imbal Flywheel
- 11" Truck Clutch and Pressure Plate
- Mustang dump Sump Pan
- 8" Skyjacker coils (replace the 6")
- Canton 90 Remote Filter Adapter
- Perma-cool single filter mount w/ brass fitting and hose clamps
Now to the pics so far
Here is what i'm planning on turning it into... (x-cab ofcourse... i was lazy)
I'm planning on snad blasting the frame in 2 weeks and then start dismantling my rolled ranger and then sand blast the suspension and come winter start putting the suspension together...
The Explorer is sitting in my garage, waiting to be stripped yet (but one thing at a time) at this time i'll slowly be added to this post.. but next year should be a good one
