new truck, questions bout '79 bko
Boggin
48
well i found an old 79 Bronco, with a 351modified big block for $400
she has a rear engine oil seal, the guy who is selling told me that you haul off the base pan and slide the seal out through? i know nothing at all about this, so could i please get some help and i dont even know what to look for when i get the base pan off, i dont even know what an oil seal looks like ;brownbag;, and are these really sasd? thanks
now i just need a way to drag it home :shok:
Boggin
48
yea youll probably want pics i forgot lol
Will
514
Gnaw Bone, Indiana
Toyota
They are not sasd--they came with a solid axle if it's a '79. I can't tell from a picture if it's really a '79. I know it's not a 1921 Oldsmobile.
I can scan complete instructions for you later. The tranny and flywheel have to come off. The pan has to drop quite a bit. The rear main cap has to come off. You make a little tool to roll the top half of the seal out using the oil feed hole. I've done it in cars through a pretty small slot.
Boggin
48
thanks and the seller said its a 79 and he said you only gotta drop the base pain for the oil seal?
Boggin
48
well sorry but i buddy of my brothers told me he had a 351 in his f150 and the Modified 351s are big blocks
Mechanickid
4
Martinsburg W.V
2.9
No I'm not making fun of you or anything, I'm just pointing out a common misconception. The 351-400 modified engines are more of a mild block. A.K.A-BOAT ANCHOR. A guy I used to work with was braggin about his chevy caprice how it had a 350 big block and a 350 turbo trans. I was laughing so hard.....
Boggin
48
big-mild-small whats the difference lol
on te bright side..
one of my buddys that i hadnt seen in over a year came in to my work last night just as i was closeing down, i nearly shit my pants. hes 22 and was gone away for work and didnt tell nobody he was coming, so i was glad to see him, and hopefully he wants to go get a bronco!
Will
514
Gnaw Bone, Indiana
Toyota
The base pan, which I call an oil pan, has to come down enough to get the rear main bearing cap off. And I take it back, you don't need to take the tranny out. I don't know WTF I was thinking. After the pan is off, the rear main cap has to be removed. In the cap will be half of the seal. Then you push the other half around out of the block. Reverse order to reinstall.
While it's apart it might be a good time to slide in some new bearings if the journals look okay. That's what you need the tool I mention for. It's make from a nail, you slip it in the crank oiling holes so just the head is protruding--trimmed to a little less than the thickness of the bearing insert--then roll the engine to push the top half of the main bearing out. Repeat to reinstall. You can do the rod bearings as well. If the oil pressure is a little weak this will give you a few more tens of thousands of miles.
One other thing, make sure the valve cover breather is clear. If it's getting clogged with yuck--which can happen on an old engine that's getting a little blow-by past the rings--the pressure in the crankcase can start pushing past seals.
Boggin
48
thank you very much man, thats a great help, do you think me and a buddy could get it done in a day?
Will
514
Gnaw Bone, Indiana
Toyota
wrecking-crew
25
dirty jersey
06 chevy
88 ranger
6 cylinders
please tell me you slapped him.:icon_rofl:
Psychopete
29
FW, IN
What would be a huge help is those plastic guides that screw into the block, and the gasket/pan slides over them, which locks them into place. Won't be so much of a fight putting it back together against gravity (IMO). I still cringe at the thought of trying to do this from under the truck! :D
Pete
Boggin
48
Pete
never heard of them?
