New to group and have some questions.
DocLips
Hagerstown, MD
302
I just picked up an 88 BII with a 302/c4 swap already done. As of right now it doesn't run due to sitting in a field for three years. Most of the work was done with JamesDuff or advance adaptor parts. The 302 was from an 87 Bronco and has full MSD blaster 2 ignition, weiand intake(unsure of which yet) and a speed demon 650cfm carb. It has a 3in body lift and 2in susp. lift as well. I am thinking about converting it to 2wd and lowering for street/strip use once I get it running again. Is there a conversion parts list for 4x4 to 2x4 somewhere? I've done some light searching and only found 4x4 to 2x4 parts numbers and lists.
SenorNoob
579
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Uhm.. The 2wd equivalent for all of the parts swapped to go the other way?
I'd say it's not a very commonly done swap.
Weren't all B2s 4x4 just without a front differential and a dummy transfer case?
If so, then the swap should just mean the beams and a 2wd transmission. (Or leave the transfer case for low range.)
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Swap the trans for a 2wd unit, get all the 2wd suspension, but it MUST be from another B2. Thats it....
SVT
