New project 1992 Ranger Fireball
Elutheros
129
Central Texas
Rowdy are you referring to the $365 starter in the performance section?
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
It don't look bad but I went the more is better route. I figured what's a days worth of work to build a crossmember when a tail housing costs like $300. I can't say if that's good enough or not cuz I've only built the one crossmember.
shortzt
What did you use for your mount? I was looking at one from tmr customs
Or
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
I found a high torque starter off eBay for $55 but I'm all for getting one from AutoZone for $60 and it comes with a LLT warranty.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Or
I built one. It looks okey but it's .25" and stout.
Elutheros
129
Central Texas
Well, the starter debacle was all on the dyslexic wiring fool--me. The alternator output was on the same post of the relay as the starter, which will definitely smoke the starter (duhhh). It runs. I'm still working on the exhaust and only part way through the fabrication of the down tubes from the manifolds. Probably running a little weird because I just put a new MAF in it and hooked up the ACT without resetting the PCM before this start.
[/URL][/IMG]
Elutheros
129
Central Texas
ideas on fixing an oil leak?
Discovered a leak coming from next to one of the oil pan bolts and I'm not sure how best to fix it. It looks like the pan has a very small crack next to the bolt washer and tightening the bolt may actually open it up more. I'm thinking a weld would get in the way of the washer. Anybody have any better ideas?
[/URL][/IMG]
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
A small dab of JB weld. Just hit it with brake cleaner then apply the JB weld.
nosferatu49426
Grand Rapids, Mi
Chevy,Ford,Jeep
5.7,4.0,4.0
X2. That stuff is awesome. I fixed my column shifter in my ranger with it.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Weld the crack, then grind it smooth for the washer...
SVT
Elutheros
129
Central Texas
Rough Idle--poor acceleration
Thought I had this whipped when I put a new upper plenum gasket on the intake and got rid of a vacuum leak. Still doing it. Checked the TPS and voltage was low, so switched it out and tried two other TPsensors. Same result--voltage is .14 on all of them. KOEO codes are 15, 23, 67, 85, 95
15 is a power interrupt to the PCM--is that because I keep disconnecting the battery to do stuff?
23 TPS out of range
67 A/C which I have not connected at all
85 canister purge
95 secondary fuel pump circuit--is this because I didn't run the additional wire from the PCM to the pump?
Don't have a fuel pressure tester
Once I get past part throttle it seems to do a lot better, but it is not running up to par. Has new 02 sensors, no CEL. New MAF. New plugs, wires, distributor cap and rotor are good, timing is set at 10 degrees BTDC.
Don't understand how the TPS voltage can be the same on every sensor and not change with throttle movement.
Elutheros
129
Central Texas
V8 tachometer install
I wanted the stock look, so I got a tach from a '95 Bronco and adapted it to fit the Ranger instrument cluster. Had to trim a little plastic on the right side, and lengthen the pins on the back so it would plug in to the cluster. I used the pins off of the old 4.0 PCM wires and trimmed the ends so I could slip them over the existing pins, then cut them to the right length and just barely crimped the ends. Works great and is accurate!
[/URL][/IMG]
Elutheros
129
Central Texas
Time to stick a fork in it
I guess I'll call it done--not well done, just medium rare. She runs and drives and there is still a list of fixes and little things that need to be dealt with, but that list will probably never end. A couple of annoying leaks need to be fixed, the interior has to be re installed, tires balanced, etc, etc. I'm glad I took on the project and I'm satisfied with the results.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Lookin good man! What's your mpg?
Elutheros
129
Central Texas
I just filled it up for the first time today, so it will be a little while before I know how much petrol it's sucking. I'd estimate about 15-17 right now, but that's a guess based on 160 miles on a partial fill-up.
