New Guy
ford4wd08
513
Alcoa, TN
2.8 V6
Hi all, my name is Jordan.
My grandfather bought two brand new bronco ii's in 1985 and gave them to my dad and my aunt.
Dad sold his off long ago.
My aunt wanted to trade her's in and they didn't make a fair offer, so my granddad bought it back from her to keep.
He drove it for quite a few years driving back in forth, checking on cattle, etc.
I learned to drive a lot on it too and used to take my grandmother fishing in it.
Sadly my grandmother passed away in 2012 and my grandfather just passed in October.
He was a huge ford fan -- passed onto me for my love of F150's.
I'll be helping my dad with his estate. He had a ton of ford vehicles, mostly work trucks, but that little bronco is still around.
He could have ran a junk yard with all he had laying around.
So after a long read, I'm going to get that little bronco and make it my daily driver.
What I've come to ask about it there is also a 91 Ford ranger that is 4x4 he has.
I was thinking of getting all the upgrades off the ranger I could before we junk it.
What should I be looking for when I do that?
Sent from my SAMSUNG-SM-G891A using Tapatalk
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
Sorry about your Grandpa, sounds like he was a good man.
About your questions, You really have to decide what you want first. Lots of stuff can swap over, but it's very time consuming and requires lots of mods. Lots of post in Ranger station on what's possible and how to.
You may want to ask this question in the Ranger section as they are more knowledgeable then I.
I personally would try to keep both if possible, can't have to many fords.
BlackBII
Ranger Custom
Truck of Month
982
UT
The '91 Ranger likely has a Dana 35 in the front and an 8.8 in the rear, both are great upgrades for the Bronco II
You could also swap the entire drivetrain; the 2.8 in the BII is quite underpowered. If the Ranger has the 2.9 or 4.0, I would swap the engine, trans and transfercase.
ford4wd08
513
Alcoa, TN
2.8 V6
Ranger has the 4.0.
I am thinking of taking the two and making the bronco the one to keep..
alwaysFlOoReD
5,125
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I had a b2 with a 4.0/5-speed/4.10/31" tires. It was a great truck. Too bad it was a rust bucket.
BlackBII
Ranger Custom
Truck of Month
982
UT
Ranger has the 4.0.
That is a very good option.
I've had a BII with a 4.0 and it's a perfect combo.
Yours is a first gen, which makes the wiring part of the swap and bit more fun, but everything is more or less "bolt in".
The firewall is a bit different in the early trucks, but if you were to swap the dash from the ranger into the BII then everything would be bolt in and plug and play. Easy peasy. You would need to figure out fuel lines and a pump, and I believe swap the fuel tank for a newer one as the older BII tank doesn't have the right hole to mount the 89-90 BII fuel pump/sending unit, which is the one you would want.
https://www.therangerstation.com/ford-rangers-buyers-guide/1986-ford-ranger-problems-recalls/wiring-a-4-0l-to-an-original-1983-1988-dash/
https://www.therangerstation.com/how-to/engines-fuel-systems/4-0-liter-engine-conversion-faqs/
https://www.therangerstation.com/how-to/engines-fuel-systems/ford-4-0l-v-6-conversion/
https://www.therangerstation.com/how-to/engines-fuel-systems/4-0-liter-conversion-on-older-v-6-fords/
https://www.therangerstation.com/how-to/engines-fuel-systems/ford-4-0-liter-v-6-conversion-wiring-from-explorer-to-bronco-ii/
ford4wd08
513
Alcoa, TN
2.8 V6
I would honestly like to keep the original dash.
I like the looks of it so much more. I know it is more work wiring, but I believe it is something I could figure out.
My goal would be to start with the 2.8 and drive it for a while, just store the ranger as is until I feel the need, or have to swap in the 4.0.
It basically would give me a spare trans, motor, and axles.
BlackBII
Ranger Custom
Truck of Month
982
UT
Sounds like a good plan.
That first link I posted should describe the wiring that needs to be done in order to keep the original dash. I also have all the diagrams for a 1992 4.0 that I can post, which will be very close to the 1991 4.0. :icon_thumby:
ford4wd08
513
Alcoa, TN
2.8 V6
Thanks! I'll keep that in mind.
ford4wd08
513
Alcoa, TN
2.8 V6
Next weekend I'm going to my see my parents and I'll go by my granddad's house.
I don't think I'll be able to bring the Bronco home until January, but I'll snap some pics of it and see if I can get it to start with jumper cables.
ford4wd08
513
Alcoa, TN
2.8 V6
Finally made it to my grandad's to get some pictures.
Looks like only 60k original miles.
Something has been living in engine bay, but I don't see any oil leaks.
Needs a paint job. Interior needs to be redone.
I would probably replace all the door seals.
It's full of junk so I didn't get any pics of the interior.
I think I'll have to tow it home and go through it a little at a time to get it going again.
ford4wd08
513
Alcoa, TN
2.8 V6
There are a few panels with dents, but doesn't appear to be any rot, just surface rust.
ford4wd08
513
Alcoa, TN
2.8 V6
Also got some pictures of the potential donor for a 4.0 and other parts.
17,936
SW Iowa
Do either run?
I am mildly impressed to see the jack handle correctly stowed on both rigs :icon_thumby:
ford4wd08
513
Alcoa, TN
2.8 V6
Do either run?
The old saying it did when it was parked comes to mind.
I suspect the bronco will be fairly easy to get running as long as somethimg didnt go nuts on the wiring.
The ranger ran really well at one time, but it has had less use than the bronco in recent years.
I can assure they were both bought new and operated by people in at least their 50's. No abuse i can think of other than sitting.
Sent from my SM-T380 using Tapatalk
