new from MONROE MI
mudtruggy
Truck of Month
48
Monroe Mi
472 ford
Solid Axle Swap 4x4
48"
Hello and thank you for letting me join the groop. I'm currently building a 1978/1999 Ford Ranger Truggy. Been in works for 7-8 years not much time to work on it but it is getting close to being done. motor is a 472 bb c6/np205 2.5 ton Rockwell axles and 48" tires with Stazworks wheels dual deadlock.
mudtruggy
Truck of Month
48
Monroe Mi
472 ford
Solid Axle Swap 4x4
48"
pictures
mudtruggy
Truck of Month
48
Monroe Mi
472 ford
Solid Axle Swap 4x4
48"
more
mudtruggy
Truck of Month
48
Monroe Mi
472 ford
Solid Axle Swap 4x4
48"
wheels and tires.
fangotango306
8
sc michigan
None yet
Welcome. Nice build so far. Im about an hour west of you. Lots of good people and info to be had on this site.
mudtruggy
Truck of Month
48
Monroe Mi
472 ford
Solid Axle Swap 4x4
48"
Update
We got all hydraulic steering lines made yesterday and fitted the shocks to figure out where to mount reservoir's.
fangotango306
8
sc michigan
None yet
This thing is insane. Love it
kunar
131
Toledo, Ohio
5.8l
Welcome from Toledo. Looking good, can't wait to see where this goes. You should make a build thread.
mudtruggy
Truck of Month
48
Monroe Mi
472 ford
Solid Axle Swap 4x4
48"
We got all the fab work bone and put on the tires to see how she looks, not bad! It is sitting at full squat truck will be about 7" taller when sitting on springs.
mudtruggy
Truck of Month
48
Monroe Mi
472 ford
Solid Axle Swap 4x4
48"
Front shot.
mudtruggy
Truck of Month
48
Monroe Mi
472 ford
Solid Axle Swap 4x4
48"
Rear.
mudtruggy
Truck of Month
48
Monroe Mi
472 ford
Solid Axle Swap 4x4
48"
Alot has changed since I've been on here but it is still not done! This is the year it will be completed. We are getting close to seeing if the motor will run, if so then we will put the axles back under her and make some drive shafts and get her weighed to figure out spring rate.
mudtruggy
Truck of Month
48
Monroe Mi
472 ford
Solid Axle Swap 4x4
48"
mudtruggy
Truck of Month
48
Monroe Mi
472 ford
Solid Axle Swap 4x4
48"
