tsayyote
- Jan 14, 2013
- 0
- Anaheim, CA
- Ford
- Engine Size
- 2.3L
So in the midst of moving and planning for a wedding, my throwout bearing decided to file for retirement Friday night.
So did some searching here and got some good info, just need some opinions on my choices. Truck is a 99 2.5 manual rcsb, bone stock with 232,xxx miles. When I bought the truck from a tow yard, I went through it and everything I could see under the hood was motorcraft, so I'd like to keep everything as close to oem as possible.
1. I intend to replace the rear main, pilot, flywheel, clutch, throwout, and slave since I'm gunna be in there. I'm looking at this Luk Repset clutch on ebay for $225 that includes the slave http://www.ebay.com/itm/LUK-CLUTCH-KIT-SLAVE-CYLINDER-FORD-RANGER-MAZDA-B2300-B2500-B3000-2-3L-2-5L-3-0L-/400388521612?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d3903fe8c&vxp=mtr These guys are 15 minutes from me so I can pick it up the same day. From what I read here, this seems to be a good kit?
2. As for the flywheel, Ford gave me part number f57z-6375-a costing $190. Being as the truck has 232k on it, I just want to replace the flywheel since I'm not sure if the one in there would still even be within spec to true, but I don't want to spend $190 on a flywheel. Should I order a Luk flywheel or is there another that would be a good choice for daily driving?
3. I'm also not sure if this truck has the 6 or 8 bolt pattern bolts on the flywheel. Can anyone clarify? I'd like to replace them too and would prefer to have all the parts when I begin the job so I can finish it quickly.
Thanks guys!
Thanks guys!
