Needing a breakdown schematic of 2.3L engine
CajunPwnStar
Lafayette, LA
2.3L
New to Fords and gas engines in general, been a new diesel tech for a while. Just looking for a breakdown of the 2.3L engine to help identify some components to aid in the tune up.
Mikel89us
5
2.3L (2.5L soon)
Well, I don't know that I've ever seen a full breakdown schematic for a 2.3... Tuneups are easy though. Spark plugs, wires, cap and rotor if it has a distributor. That's pretty much it, except fuel filter.
CajunPwnStar
Lafayette, LA
2.3L
Yea, I've searched around an couldn't find anything. I'm just not used to dealing with the vacuum system and some other components I'm not recognizing, since we don't have those on the large Cat engines.
tomw
46
lima bean
vertical and above ground
++The best source for what I think you want to know about is the EVTM - Electrical Vacuum Troubleshooting Manual - for the year of your truck.
It has diagrams, schematics, connector breakdowns, test points for some components, and a description of the 'theory of operation' of a lot of systems.
If you can find one, you will find it valuable. IMO. Best bucks I've spent ever on documentatation.
tom
CajunPwnStar
Lafayette, LA
2.3L
Thanks, tomw. I think that will help. I've never had to learn the vacuum system operation, therefore don't know much about the components involved.
CajunPwnStar
Lafayette, LA
2.3L
wizkid, I'll check those out after work.
To give a clearer explanation, we have these manuals for all of our engines. Just goes through each component and has a parts blow out. This is an example from a Cat C13...
Hagan
08/2013 OTOTM Winner
11
Salem, OR
2.3
I think what you are looking for is a parts fiche?
I've never seen one for these engines.
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
On a '95 there shouldn't be too much vacuum activated, there's the EGR flow sensor deal, the vacuum actuated heater valve, the evac canister, and the brake booster... there should also be a vacuum diagram under the hood on a sticker
No members online now.
