needin a cross section of transmission shifter
desertjoe84
New Mexico
2.8
I got a mig, a cuttin torch and a grinder,,and I ain't afraid to use em.
Hello All,,, I just got a 1984 BII with the 2.8, 4 Sp (5 SP?) and 4X4 with 85,456 real miles. I haven't got it to run as some thieves stole the starter, starter solenoid, ignition coil and the rear driveshaft,,,,,sheeesh,,, I got a new starter, and solenoid at O'reillys then I realized the ignition coil was also missing, along with the plastic connector,,,!!!
The reason the PO parked it was the trans had locked up in reverse and they broke the plastic "guides" on the shifter and shifter would just spin around and not go into any gear. I was able to find a used shifter at a wrecking yard today but it is not exactly like mine. I'm not sure if mine is a 4 SP or a 5 SP, but some literature on driver side visor states methods for overdrive shifting ( 5 SP?)
The metal part on MY tranny that slides forward and back or sideways does not snap back to center like the BII I took the shifter off of. The donor BII tranny seems to have some springs that make the "center part" where shifter goes,,snap back to center position. Hopin somebody can make sense of what I'm trying to describe.
Does anybody here have a manual that shows the shifter section of tranny for the 84's?? NOT lookin forward to pullin the tranny,,,,!!!
I went to the local Ford house to see if I could look at their tranny manuals and they told me they would fix it but did not loan out their manuals,,,,,,,,,S***A****'s,,,!!!!
Can anybody help,??
alwaysFlOoReD
5,118
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
desertjoe84
New Mexico
2.8
Hey AlwaysFIOoreD,,Yeah,,I had looked at all those but the trans they show is different from mine. The shifter hold down is round and has 3 bolts where mine is square and has the 4 hold down bolts. The 1986 trans I got the shifter off of also had the square bolt pattern, but was different inside the trans,,,???
Where to from here,,,???? Anybody got a shop manual,,?? THANKS
desertjoe84
New Mexico
2.8
Guys,,I'm really needin some help with some info, here,,,,,I did verify thru the tag on the door that it is a 5 speed trans and PO tells me they never did anything drive train so, trans is original to trk. Trk was made in 07/84.
There IS a manual for sale here but info says it for early T5 Ford trans,,,???
Surely someone here has a Ford shop manual,,,,???
RayInStl
14
St. Louis, MO
2.3L
Well, that didn't work. Let's try something else!
84 B2s only came with the 4 speed TK4. Are you sure it's an 84? 85 could have had either the TK4 or TK5, the 5 speed version of the TK4.
Mac
183
C. Wisconsin
2000
199
I had a 1984 B2 with the 5 speed, bought it new. Picked it up late June, maybe a mid year change?
Dave
RayInStl
14
St. Louis, MO
2.3L
Dave
That's what I get for trusting bronco corral's tech pages! Lol.
For what it's worth, the tk4 and tk5 both have square shifter covers with 4 bolts.
Ilike55s2
Hey fellow Members,,,Well,, after several months of working on getting this trk running again,,,,I have decided to sell my 84 Bronco 2.
I ain't figured out how to post pics but if interested I can email you some.
The trk is a LOW mileage (85,456) Bronco II with the original 2.8, 5 speed, and 4X4. Trk also has factory A/C. White outside and red inside. Has the factory spare tire carrier at back lift gate. Original Radio works good. This trk was originally purchased in Alamogordo, NM and spent all its life there, so , no rust out panels here.
It now has the Duraspark Conversion with new distributor, cap, wires, Ignition Module and Coil. Rebuilt 2 barrel 500 CFM Holley. The engine, transmission and 4X4 all work great and engine starts right up. Also has new ignition cylinder with 2 keys and the 3 doors all open and lock like supposed to. Has dual exhaust with glass packs that sound great.
Contact me if interested.
17,889
SW Iowa
