capri1979
- Feb 24, 2008
- 0
After reading this In the awesome tech libraries here at thetangerstation:
The hydraulic clutch, slave cylinder/throwout bearing is another item you should pay close attention to. After time, the slave cylinder fails to release the clutch completely. If you are having trouble shifting into 1st and reverse while stationary or if your truck creeps forward with the clutch pedal depressed the slave cylinder/throwout bearing is probably at fault. Unfortunately there is no easy fix here as the transmission must be removed to replace the combination slave cylinder and throwout bearing
I realized that the slave i installed new 2 years ago was crap. I bought it from a local part store that i thought i was getting a deal at.
Anyone have a good recommendation where to get a reliable one? The truck did exactly what this states from day one. The junkyard trans i installed is taking a crap, so i need to pull it anyway. I stopped buying things from this local store and since bought at autozone, but i am leery of them to. Napa? Ford? Thanks!
