need help
PaleBlue90
5
Aurora Colorado
FORD
2.3,2.9 and 4.0
ok so i went playing in mud at zombiefest. for a while now once in a while my blazer (350 SB) surges.
the RPM will go from 500 in gear to 900 and then back and forth. it does it once in a while. it also sounds like im missfireing. the plugs are new and gapped at 35 degress, dizzy is new. plug wires are not. is it possible that my plug wires are bad causeing my surgeing and missing?
timeing is also set dead on at 14 degrees advanced
*EDIT* this has been going on before any mud or wheeling
martin
26
St Bruno, Quebec
1991
could be a problem with the ignition module. little more info in the motor might help also, carb, efi, etc.
