need help with base tune for turbo ranger 2.3
donnytrash
Truck is a 94 ford ranger
I am switching over from tweecer to binary editor 2010. I'm going to use a D1L1 eec because its more supported. I have 42lb injectors 80mm maf from a lincoln mark 8. Pushing 7 psi as of now but will like to do a lot more. The bottem end is built with wiseco pistons , chilald and albert rods , arp studs. Front mount intercooler with 2.5 pipeing. I'm useing an lc1 wideban. My truck is a dezert prerunner so it needs to keep the temp down and have a safe tune. I have the stock ranger fuel pump as of now. I'm looking for some help with a base tune and someone that can show me around BE on the proper way to tune for higher boost.
Thanks in advance
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
Howdy...you may find more information on this application in the Forced Induction thread...turbo stuff is a bit more complicated than regular carb or EFI...and there are people in the Forced Induction thread that should be able to give you more specific info...
I've never ventured there but I'm sure someone has done something similar...
