np205
- Aug 9, 2007
- 18
- Age
- 46
- Port Angeles, WA
- Ford
- Engine Size
- 7.3
Around 410 for a Powertrax no-slip or 320 for a Lock Rite
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Huh? Limited slips have spider gears just like open diffs. You can't weld the side gears to the case, but you can weld them to the spiders for the same effect. As long as the cross-pin can still come out (you won't be able to remove a broken axleshaft otherwise).You can't weld a limited slip, you'd need an open diff to weld it up. Kind of hard to weld to clutch packs.
Whaaaaaaaat... were there ever clips in there? Because if you don't have them, you need them. Open diffs and limited slips both have c-clips.there arent the c clips in there
I would never run a welded carrier without welding the spiders to each other and to the case.Huh? Limited slips have spider gears just like open diffs. You can't weld the side gears to the case, but you can weld them to the spiders for the same effect. As long as the cross-pin can still come out (you won't be able to remove a broken axleshaft otherwise).
Though I really don't like how a welded diff handles. At all.
