My dual muffler, dual exhaust system
ghunt81
Clarksburg, WV
I wanted to show you guys the exhaust system I pieced together in my garage.
I didn't set out to build it this way, but I couldn't get a sound I liked with the Flowmaster knockoff I was originally using and I was trying to get the truck done inside of 4 days.
So, here's the story:
Originally I started out with a Dynomax 2 1/4" mid-pipe (cat to muffler), Dynomax 2 1/2" tailpipe, and a Hooker turbo muffler I found cheap on ebay. I also used the Dynomax muffler bracket they include in their cat back kit.
Drove it this way for a week, didn't really like the sound, and the tailpipe kept falling down because it didn't fit the muffler very well. In general it pissed me off and I didn't need the truck right at that time so I decided to park it and work on a dual exhaust setup.
I originally had this big weird "Flowsound" muffler that was basically two-2 chamber mufflers end to end in one long case. I also bought Heartthrob tailpipes, cut them down a bit and welded 45's on the end so I could exit it out the sides at a 45, with 3.5" x 18" Jones stainless tips.
I put that all on, drove it around, hated it, and it was louder than I wanted. Took it back home and needed it done in 4 days. Couldn't get a single in/dual out muffler locally that I knew of but an idea popped into my head to run dual mufflers off a Y pipe.
So, I went to advance auto parts and bought 2 Thrush Turbo mufflers and a section of 2.5" pipe.
Took that all home, hacked up the 2.5" pipe and built a Y-pipe (yes I have a flux core mig so the welds are a little ugly):
I modified the Dynomax bracket (pretty much just cut off the ends of the hangers and reversed them) to offset it enough to fit on the outside muffler with the Y pipe attached.
Since there was nothing supporting the inside muffler, and there was a hole in the frame near the rear of the mufflers, I built a frame bracket to hold a rubber isolator, and a hanger that would give a sort of cantilever support to the inside muffler.
And the end result with the tailpipes was this:
I'm happy with it, sounds good at idle, pretty mellow through the RPM range...still a bit buzzy but it's a V6 so what can you do. I mostly did it for looks and on that I am very happy, it looks great and the 18" long tips worked perfect for this.
kevinbmx77
Instead of making one pipe go into two mufflers cut the place where the two manifolds meet each other (the stock y pipe) and make it a true dual where the pipes never cross. It will sound like a v8 at idle and when not ran hard
Sent from my SM-G920P using Tapatalk
ghunt81
Clarksburg, WV
I thought about that but I'm a bit leery on cutting the factory Y pipe, especially since I'm not sure how long I will keep this truck.
kevinbmx77
I just did mine today, its not worth the effort and pain to get it done right
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
you will lose power with straight pipes.
neat job though working with what ya got.
