my dana 44 hp swap(pics)
93 4x4
florida
There 5.5 bronco with a 3/16" circular plates welded to the bottom of the spring perches to reinforce them and 1/2" wedge between the perch and axle gave me 9" of lift
strangeranger
Can I have a up-close pic of the plate and wedge on the bottom of your front coils. How is that you got 9inch lift out of 5.5 and a 3/16 plate and 1/2 wedge?
93 4x4
florida
When you use 5.5 bronco springs a ranger doesn't weight as much as a bronco so you get 8"+ 3/16" +1/2" = 8 11/16" plus when I used the f150 spring buckets i chopped them and got another 1/2" so 9 3/16" .heres a shot of the setup
[/IMG]
strangeranger
Thanks man. Im doing the same setup but Im also swapping in a 302 so I might not get the same lift cuz the weight of the motor. but we will see.
strangeranger
Also wat shocks did you use? and wat brand of wheel adapters did you use?
1985Ranger124
Penngrove, California
171 V6
I got a question. With that gear ratio how does it crawler and whats your maximum speed.
59bisquik
April 2011 OTOTM Winner
Solid Axle Swap 4x4
Great looking build! How does she ride with the track bar angle? Mine looks similar, and has some bump steer. Whats your angle?
buell-eyed-devil
21
Wesley Chapel,Florida
FORD
5.0-ZF in process
3"body on new poly body mounts
Hey ya'll, watch this
What radius arms are you using? Sweet setup by the way
93 4x4
florida
the shocks are rancho RS5000's and i just got the wheel adapters off ebay, there just a typical billet aluminum spacer.
i have 4:56's, it will creep pretty well in low range 1st, and have been over 85mph on the highway!
it rides great! i have no bump steer at all actually, the angle is 14*
thanks! there just regular '73 bronco arms :icon_thumby:
93 4x4
florida
yes, It was easy to do
59bisquik
Solid Axle Swap 4x4
Thanks! I will check mine and see how steep it is.
Andres629
11
Saskatchewan!
2.9 screamer
Quick question... still using the factory brake master? What's your braking power like?
