- Jul 7, 2009
- 17
- Loganville GA
- Ford
- Engine Size
- 4.0
Sweet looking ride... Helluva job!
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Haha yes they just bolt into place once you remove the axle shafts from an f-150 have them shortened and re-splined and install them into an explorer rear axle.did the bigger drums from the f150 just bolt in to place?
As soon as i can afford a paint job it will be 1 colour.what a build!! now just get that truck all one color!
couldnt you have had the explorer axles re drilled for 5*5?Haha yes they just bolt into place once you remove the axle shafts from an f-150 have them shortened and re-splined and install them into an explorer rear axle.
But if the question is do the backing plates bolt onto the axle, the answer is yes they are a direct bolt on. The tuff part is the axle shafts. You can have them custom made cheaper from Moser with a lifetime warrenty. The problem i had with that was a crap load of measurements that i would have to take off both axles. What i did was took 4 shafts to True Gear in cambridge and told them i need the long ones the smae size as the short ones.
Yes I could have, but that would be getting very close to the edge of the flange(whatever you want to call it). Plus it wouldn't look very good. I like that the rear axle looks like nothings been done to it, well besides the perches, but its not that noticeable.couldnt you have had the explorer axles re drilled for 5*5?
must resist...
