- Aug 7, 2007
- 6
- Age
- 42
- Calgary, Alberta
- Ford
So after having a Sky Jacker 4" lift kit on the truck for the last two years, I'm really not all that impressed with it. The ride quality hasn't been all that great, and the shocks have already started leaking (one of the rears started leaking quite a while ago actually), and keeping an alignment hasn't been all that easy (it keeps wanting to pull to the right). So I'm going to take the plunge to do a SAS using a high pinion D44 from a '79 Bronco, and to support it I'll also build up an Explorer 31 spline axle for the rear. Ask any questions you feel...
Got myself a D44 back in the late winter/early spring:
tore it apart and found that it had been abused pretty badly....the guy that had it before never changed a seal or diff oil:
Fast forward to the last week or so, and I tried to clean and sand blast the diff but there was way too much heavy grease on it, and a black scale inside it:
Also got myself a diff from a '97 Explorer, so it's a little wider to better match the D44, has 31 spline axles, and is also going to get cleaned up:
Both diffs going to be hot tanked...it's hard to find any shops that actually have hot tanks anymore:
D44 back from being hot tanked, sand blasted it a bit to remove some surface rust, primed....also has a brand new Solid Axle Industries nodular iron cover on it (just to see how it looked LOL):
The 8.8 also back, sandblasted, and primed. Also with a Solid Axle Industries cover on it:
Starting to get all the parts that I'm going to need...got some 1 ton chev tie rod ends, new ball joints, bearings, seals, etc:
I'm going to need to flip the 8.8 for spring over axle, so I've also picked up new shock and spring mounts:
I found a guy selling a set of Cage radius arms out of BC...lets just say it was a whole lot cheaper than buying them locally!
Massive rod ends for the Cage radius arms...these things are big. However, I am a little worried about the durability of these in a daily driver...
New rims...15"x10", 5 on 5.5", and about 3.75" backspacing....
I'm going to set up the axles, get all the parts I can possibly amass, and then work on a marathon build to get them installed when they're ready. First on the list is to get the D44 shortened 6" on the pass side to become an early bronco width. This way it will fit under the Ranger a little easier and without custom flares being needed...that and I don't want to run full width axles. The rear Explorer 8.8 was chosen for the beefier 31 spline axles, bigger bearings, and it's a little wider so when I put the wheel adapters on it, it will become the same width as the built D44 front.
Lockers are on the way, with an Eaton E-Locker for the front and an Auburn ECTED for the rear. Being a daily driver the ECTED will give me a limited slip, and a locker when I feel like playing. 4340 Chromoly shafts are on the list to order as I need new ones anyhow with the D44 being shortened. As for actual lift height...I'm hoping for only about 5" over stock, but will probably be about 6" when all is said and done. The front D44 will actually be pushed about an inch forward from stock to allow the tire to be centered in the wheel opening, and thus I shouldn't have to trim any body this way.
I'll keep updating as I can and as I am able to get stuff done. I hope to get this thing out wheeling as soon as I can now that I'm taking the plunge!
