mustang wheels on a 1995 b2300
Bargs
mazda
Got a question,I have a 95 mazda b2300 2wd that I had early 2000s mustang aluminum 5 spokes put on with 205. 55. 16 bfg.. I am having it lifted a little..drags on our dirt road too much..wanting to know if I add bigger tires a all terain with this rim with the different inset or offset..they are 16x8 I think.. a little inboard in front. Thanks..
enjr44
9
Renton, WA
02 2X4; 08 FX4
4.0 SOHC
You are asking a question that is, Yes!" "Maybe!" "No!"
Since you are not giving any specifics on what tires you want to use. So, depending on the tire size you select the answer will change.
An optional tire/wheel for that year was 275/75R 15 which is 27.7 inches tall. The tires you have on there are 24.9 inches tall.
A 215/75R 16 is 28.7 inches tall. A 225/75R 16 is 29.3 inches tall. And, a 235/75R 16 is 29.9 inches. I think (I don't know) the 235 may/will fit without hitting anything. That would give you 2.5 inches of additional ground clearance.
But, you will have to verify by actually installing one. To verify, I would get dealer to mount one and give it a go.
Bargs
mazda
mustang wheels.
Thank you sir..I think I'll be good in the back,had the 1.5 inch 1 3.8x3 washer spacer made up to level the front.gonna have them installed.then see what fits..
